Well, I definitly thinck you are better off making them yourself (if you have a lath).scooble wrote:sorry Jan, don't have any dimensions. I was thinking from the point of view that VHM inserts are off the shelf for a number of models, therefore, if possible, may only require half the machining. Outstanding work by the way, good to see the resourceful KR spirit alive and kicking which is sadly lacking on many other forums
making the insert really is by far the easiest and cheapest part of it. I bought an aluminium bar, 80mm diameter from which I can make 5 or 6 inserts, for 20 euro. 1 blind VHM set's you 29.90 back.
