Posts: 3403 Joined: Mon Aug 02, 2010 10:22 am
Post
by 500bernie » Fri Dec 23, 2011 1:31 pm
Hi Guys n Galls,
What lube should I use on the valves during assembly?
I presume they should rotate nice and smoothly with almost no effort required?
Posts: 3926 Joined: Fri Jun 18, 2010 11:29 am
Post
by Luders » Fri Dec 23, 2011 2:30 pm
Just wipe a bit of 2 stroke oil on them
Post
by Luders » Fri Dec 23, 2011 2:34 pm
Yes they should rotate with the finger nice and freely.
How's your knee doing?
Post
by 500bernie » Fri Dec 23, 2011 3:09 pm
Hi Ben,
Twisted it the other day and put my recovery back about 3 weeks, getting better though, just came in from a limp with the dogs.
Post
by Luders » Fri Dec 23, 2011 6:44 pm
take it easy with them
Post
by 500bernie » Fri Dec 23, 2011 9:12 pm
Luders wrote: take it easy with them
Wot... the KIPs or the hell hounds?
Post
by Luders » Fri Dec 23, 2011 9:43 pm
your knees
Posts: 3322 Joined: Wed Jul 26, 2006 11:50 pm
Post
by JanBros » Sat Dec 24, 2011 12:47 am
I use copper-grease
Bikemike
Posts: 1193 Joined: Tue Jul 25, 2006 8:51 pm
Post
by Bikemike » Sat Dec 24, 2011 9:42 am
JanBros wrote: I use copper-grease
For your knees?
Post
by 500bernie » Sat Dec 24, 2011 9:44 am
Bikemike wrote: JanBros wrote: I use copper-grease
For your knees?
Being the wrong side of 50 I will try anything (except the 5 spoke gay thing
Post
by Luders » Sat Dec 24, 2011 10:37 am
You could try some durex play, the tingle one works best!
Post
by 500bernie » Sat Dec 24, 2011 11:48 am
Luders wrote: You could try some durex play, the tingle one works best!
On my knees
or on the KIPs
Post
by 500bernie » Sat Dec 24, 2011 3:39 pm
Hi Jan,
Do you put it on the spiggot at the bottom of the valve and on the stem where it goes through the head?
Post
by JanBros » Sun Dec 25, 2011 2:50 pm
just at the bottom actually.
on top there is too much play, I believe the only thing that is keeping the valve in place on top is the seal.
Now with my new head with changeable inserts and lowered cylinders, I also had to take some material from the top ring off the valves, because they were sticking out above the cylindres. Now they have just the minimal clearance and no longer jump up and down, so I putted some grease on them to.
Post
by 500bernie » Mon Dec 26, 2011 9:52 am
Thanks Jan,
I have watched your post about the head inserts with great interest
I am using a set of F3 valves from Charles I think they will be a good fit with only a small clearance between the top shoulder and the underneath of the head, so I may put some grease there as well.
Cheers Bernie
