Billys KR-1
Billys KR-1
My KR had its first run yesterday
Have bought it to use as a track day toy and in its short time in my ownership (bought 23-01-07) has provided a great deal of fun tinkering and researching . You guys are providing a heap of information , thanks .
She has had a few knocks along the way and the engine was a bit unknown . Needed new disc and fork seals before a day at the track could be considered .
Most dealers here don't have much for KRs and seem to treat them as a bit of trouble , so it was a pleasant suprise to find fork seals of the shelf at my local kawa dealer .
Replacing the seals was easy , once we made up out version of a kawasaki special tool
Disc are bloody expensive but got onto a bloke who re-rivets new rotors onto the original carriers .
The ride day went really well and the KR behaved bloody brilliantly . This was my first time on the track too .
The engine revs out fine to 11 grand and seems to get along pretty quick . Have removed the speedo so no idea what she is doing .
The brakes seem to pull her in well enough but lack feel and do not inspire confidence . Any thoughts ?
Next in line is to get a new set of boots , GPR 70's and some firmer fork springs . A set of "s" pipes are available so will try to get them sent from South Aus ASAP . That should stuff the budget for a while .
Oh the new graphics are contact book covering and stick on pin stripe tape , cheap and cheerfull
Cheers Billy
Bugger , wrote this expecting to post some photos , sorry will have to work on that .
Cheers Billy
hi billy
open up a photobucket acc
http://photobucket.com/
up load the pics from your computer to p/bucket
then copy the [img] from there a paste onto here
cheers lee
cheers lee
2 strokes our way of life
- Site Admin
Re: Billys KR-1
Braided lines will sort them out a treat, you won't believe the differencethe kid wrote: The brakes seem to pull her in well enough but lack feel and do not inspire confidence . Any thoughts ?
Al
Re: Billys KR-1
Also get some decent brake fluid in there. Over ere the best (and cheapest) is Halfords own brand 5 dot one. I'm sure you must be able to find something simular over there. The brakes on a Kr1S are awesome so if you can get some 1s fork bottoms then the calipers will be easy to find and the difference will be unreal. Big K even used the Kr1s calipers on the early zx9r, that's how good they are as standard. Believe me I can get though 2 front tyres for every rear cause they get destroyed by the excellent brakes.alimorg wrote:Braided lines will sort them out a treat, you won't believe the differencethe kid wrote: The brakes seem to pull her in well enough but lack feel and do not inspire confidence . Any thoughts ?
Al
It is a bit wierd but since it is cracked I will replace it ASAP . Im only using my KR for track days so being tucked in down a straight with the world going green isn't a problem but I think it might be a bit disconcerting on the road .KwakOn wrote:Hi,
whats it like peeping through the green screen?
Actually nice to see things a bit green around here , quite the drought we have going ATM , everything very brown
