electrical running fault
Posted: Tue May 22, 2012 5:25 pm
by slashing
I have replaced the stator coil plugs an plug caps and pick up coil the bike ran fine for 60 miles when i got near to my home the rev counter started to play up it wouldnt go above four thousand revs and the neutrel light was getting dimmer and flashing on and off. I thought this could be a dodgy rectifier so i changed it for a new one from electrics works when i started the bike up it did not want to rev properley an the powervalves were opening an closing every now and then can any one help i dont knowwhat else to try can any one help please.
Posted: Tue May 22, 2012 7:20 pm
by pablo
CDI :-k There's not much else left.
Posted: Tue May 22, 2012 8:02 pm
One of the above has likely caused the CDI to fail, so if you've replaced everything, get a new tacho and CDI and you should be fine.
Posted: Fri May 25, 2012 8:20 am
by slashing
Luders wrote:One of the above has likely caused the CDI to fail, so if you've replaced everything, get a new tacho and CDI and you should be fine.
Thanks chaps.
Posted: Fri May 25, 2012 8:51 am
by headcoats
Could it be a chaffed wire ? shorting out somewhere ?
