Plugs
Posted: Wed Feb 21, 2007 9:19 pm
by the kid
Have noticed you guys seem to use BR10 plugs but the man says standard is BR9es
Am I right thinking the 10 is a colder plug ? Why run a 10 ?
Have run B9es plugs last time out (no R in stock at the time) with no dramas , but have a set of BR9eg to put in for this weekends outing . Anything to watch out for with this plug ?
Any info from here would be great (tend to rely on info from here rather than half the crap I get told by shop staff and others :roll: )
Posted: Wed Feb 21, 2007 10:14 pm
by Cliff
BR10ES was specced for the Kr-1S, BR9ES was for the Kr1. I'm sure it's ok to use the 9ES in the KR-1S, it's just that the 9ES plug runs hotter, so it will be more likely to hole your pistons if you go flat out for any length of time.
Posted: Thu Feb 22, 2007 12:15 am
Cliff wrote:BR10ES was specced for the Kr-1S, BR9ES was for the Kr1. I'm sure it's ok to use the 9ES in the KR-1S, it's just that the 9ES plug runs hotter, so it will be more likely to hole your pistons if you go flat out for any length of time.....
... so in wintertime, when the roads are slippy and you don't (wanna :lol: ) ride full throttle, BR9ES are perfect for an S :wink:
Posted: Thu Feb 22, 2007 12:38 am
by youngjon
Do people tend to use straight forward BR10/9's or iridium/splitfire/exotic/expensive variants?
Posted: Thu Feb 22, 2007 1:47 pm
by SHimmer45
ordinary NGK BR10/9ES are fine.
i think there is some more info on the team sparrow website.
links on the main page i think
Posted: Thu Feb 22, 2007 7:37 pm
by the-elf
both MJ and I run NGK B10EV gold plalladium plugs which are designed for two stroke MX machines. no problems with them in an entire season :D
