Page 1 of 2
front axle
Posted: Fri Jul 13, 2012 3:00 pm
by SP_BOTT
Hi, bit of a thick question, but I cant get the front wheel axle tight? It appears the threads bottom out but I can still turn the speedo drive through the fork tang (ie the bottom legs can be sprung apart easliy)
I've got the speedo drive in, and the RH spacer. (wheels newly powdercoated with new bearings, replated axles and spacers)
Am I missing something obvious? or doing something out of sequence??
Posted: Fri Jul 13, 2012 3:47 pm
by maccas
Try putting the axle in from the other side.
Have a look at the parts fiche to see which way round the axle should be fitted from.
I might be way off the mark with that though
Posted: Fri Jul 13, 2012 4:52 pm
by SP_BOTT
Good idea, never even thought of that, I did put the short bit speedo-drive side?
Posted: Fri Jul 13, 2012 8:46 pm
by headcoats
The little lugs holding the speedo drive housing soon get rounded and can twist out
Posted: Sat Jul 14, 2012 5:41 pm
by SP_BOTT
Posted: Sat Jul 14, 2012 6:28 pm
by Rocket
what is it like with spindle through speedo drive, wheel, spacer and into nut and tightened out of the forks.
Posted: Sat Jul 14, 2012 6:37 pm
by Howie
Do you have a Kr1 or Kr1s?
Posted: Sat Jul 14, 2012 9:13 pm
by martin
my guess is , are the bearings the correct ones, and are they fitted correctly.
right bearing pressed in until it bottoms out and then speedo side pressed in gently until there is no free play on the spindal,
if the bearings are fitted correct, and you have the spacer and speedo drive
fitted, it should be fine [is the spacer ok, it has,nt been shortened, has it
Posted: Sat Jul 14, 2012 10:19 pm
by SP_BOTT
I tried it without the wheel, and it seems as though all bolts protrude through perfectly, (each end of the spindle sits just about flush with the fork outer, and just sticks past the inner face by about 1mm)
My suspisions were the bearings too, but they were direct replacements (all fitted correctly, it's the sort of thing I do for work) what are the spec, just standard roller bearings I assume, not thicker jobbies?
I do have a spare bike I could try and swap the spindles over with? but cant see the need, as I only have this one in bits?
BTW it's a KR-1s
Posted: Sat Jul 14, 2012 11:05 pm
Was it ok before the bearrings swap ?
do you have another spacer you can try/measure ?
maybe you just have the wrong one.
Posted: Sun Jul 15, 2012 5:17 pm
by SP_BOTT
Another update before it gets torched
took the spindle out my other bike (or more specifically a wreck) and everything measure exactly, or as close as you can without a micrometer. Put both spindles together side by side, and there's no difference, swapped them over and still the same??? (forks spring open, and speedo drive turns)
is everyones the same and it's not been noticed before? highly unlikely I would imagine.
So what next clever people?
This is without the pinch bolts tightened or fitted so far.
Didn't check it before Jan as I just took it apart as you would a restoration project. Nothing looks untoward or machined/filed etc and the bike looked very genuine and original.
Posted: Sun Jul 15, 2012 6:44 pm
by Garry
Sure someone told me once the KR and S speedo drives are different
I Know the axles are different but have sold all my KR running gear so
can't compare the drives
Perhaps one is narrower than the other
Posted: Sun Jul 15, 2012 9:19 pm
by 375
Do you have a front wheel from the other bike you can use?
Put the new refurb wheel in the other bike.
Have you riden the bike before or was it a project from the start,
Do you have the old bearings to compare with,
Any bits missing from inside the speedo drive.
Posted: Sun Jul 15, 2012 10:12 pm
by SP_BOTT
Will give that a go I think, got to jack the wreck up, swap speedo drive first, try my refurbed spindle in that. Was always a project to me, all I did was start it then strip it, bearings also hit the bin a while ago, but might have one left?
On nights so will try a wheel swap when I'm day off, and speedo drive looks like the one off the wreck too.
Thanks so far.
Posted: Mon Jul 16, 2012 5:51 pm
by Howie
This is a bit of a tricky one!
I have a bare Kr1s wheel, would you like me to measure from the bearing to the lip just to make sure your bearings are in deep enough?
And if you poke your finger through the bearing onto the spacer between, is it loose at all?
