Hi Scoobie,
Are the powervalves working exactly as they should?
Just over 40hp is not right,if the vlaves are left in the low end position(below 8000rpm) then they only give about that.
What exhausts are you using?
Many years ago i had Bob Farnham "race tune" my B2,i wish i hadnt,it went from a flier that would red line in top on stock gearing to something that wouldnt pull top gear no matter what revs you went to in 5th,even running lower overall gearing didnt help.
After playing with different carbs,jetting,airbox,no box,3 sets of pipes,different ignition timing etc etc i had enough.
I took it to a guy who tuned my MX bikes,he had a look and all that had been done was the exhaust port opened right out,the barrels skimmed so now the powervalve collets had to be machined down and thats about it. =D>
Apparently this is typical of what messrs Farnham and Stevens call a tune,he had countless Stan tuned engines that had the same treatement,a big gaping exhaust port so it revs but thats it.
Farnham worked with stan before going it alone and it appears he kept to the same thinking.
This also wasnt the only case i came across,a 375 race tuned lc,rd500 stage 3 and an rd150lc farnham race tune,none of these machines would pull top and were a nightmare to get running right.
Back to the kr,the Mx engine builder did some work to the transfer ports and flowed the cases,i got it back and it was/is an absolute missile on road and track,it pulls fine from 6 but takes off at 9 to 12 and will pull higher than stock gearing.
I ran this with stock B2 exhausts and airbox initially,later S pipes and finally went for pete gibsons blown race pipes,it worked well with all these pipes,i also ditched the rear half of the airbox lid as the with the stock carbs there is not much to be gained in junking it.
bear in mind this was AFTER someone had already "had a go" at the ports,MX guy had a look at some stock barrels i showed him and said he wouldnt have opened them up at all,you dont need/want BIG ports to get results.
if you have another set of barrells i would stick them on,i really dont think you want to tune the KR as such unless you get to a level where you are riding the wheels off it all the time,reliability,driveability and well setup suspension,tyres and brakes will make the most impact in lap times.
Hope you get it sorted as it seems you had a bad 1st race weekend,not something you want when it costs so much (time and money).
ATB
Dave
