gearbox dont want to go from first to second
Posted: Fri Sep 14, 2012 3:40 pm
by fred
ime going to have a look now,it goes in first fine and positive ,doesnt like going into second but once engaged goes through the gears fine :?: i ts like the shift mechanism has`nt got enough movement up into second,strip down tommoz
Posted: Fri Sep 14, 2012 6:36 pm
by martin
try turning the trust washer around
Posted: Fri Sep 14, 2012 6:48 pm
by fred
clutch side behind basket
Posted: Fri Sep 14, 2012 9:44 pm
if it does it only in one gear, my guess is a bent/worn shift fork :wink:
Posted: Fri Sep 14, 2012 11:11 pm
by dave32
I had a problem with the return spring that is in the cover (left hand side of engine) behind the gear change lever,might be worth checking this area first as its only a 10mins job.
:D
Posted: Sat Sep 15, 2012 3:55 pm
by fred
sorted , the rivet in peg on the rose joint had come loose and the arm was hitting the frame #-o welded up now ,
Posted: Sun Oct 07, 2012 9:18 pm
by mgtkr1
selector forls. i have had it were a duff output shaft bearing caused similar problems. id swap the forks first though, its only an hour job. the bearing im refering to requires splitting the cases.
