banditbob's engine
banditbob's engine
After this poor motor had picked a fight with a courier and lost, Bob left it with me to see what I could do about the damage.
The kips valves were mangled, the lower exhaust studs bent. The main crank case was damaged around the clutch side. Broken clutch star and missing clutch inner case with missing clutch out case lever to name a few of the issues. I lost count of how many bolts, circlips, washers and god knows what else was missing from the poor old thing.
Here's what it's looking like now.
Good luck Bob, hope you're pleased with it.
dave32
Post by dave32 »
Looks good,top job! :D
Is it an S or B model?
Did you do the MJ mods to this engine?
It's an S engine and it's had full bottom end tune as per my interpretation of what MJ showed me and what I do on my own race engines.
I've not done that much to the top end other than a bit of work on the transfer ports. The kips valve areas had already been matched to flow with the valves. The head had already been setup and profiled to 0.75 squish running Vertex DT125 pistons.
I've obviously removed the oil pump and blanked it off and upgraded the clutch springs.
Flywheel is off at the moment ready to be lightened and I think that about sums it up as far as I can remember.
Should have a fair amount of poke whilst remaining reliable.
banditbob
thanks
Post by banditbob »
Hi Ben just home from work had a look at the engine ,wowwwwwww, you would,ent know it was the same engine thanks for all the hard work .
Good luck at cadwell . bob
Bob's engine ran in on my bike yesterday at Rockingham.
https://www.youtube.com/watch?v=FPTna5u ... ata_player
Rocket
Post by Rocket »
sounds ok,
you got the fork seal sorted then,
any news on the cogs.
Thanks to Andy B, he did my seal. I've not phoned them lately, will give it a go tomorrow if I get chance.
Rocket wrote:sounds ok,
Just got off the phone to him and he's saying 3 weeks now, which is the best answer I've had to date, so I'm going to phone back middle of November. =D>
banditbob
gearbox
Post by banditbob »
Hi Ben just to confirm i will take one set of gear ratios when available cheers bob.
