Its about time I pulled my finger out
- nate
Hi all,
Well, with the weather finally getting better, I thought it is about time I actually did something with my KR1-s
I got it of flea bay almost 18 months ago and spent last year stripping it down. I really want to put it back to its original former glory... Its a 1990 S version, green and black which I love... I had one years ago for a very short time, so I just had to get one... When it was running, my neighbour hated it!!!
So anyway, here are some pics of it so far
As you can see here, the frame and swing arm have been powder coated, the wheels have been sandf blasted and sprayed with 2-pac with a lacquer over the top to protect them
The rear shock is with a mate who is a hydrauics engineer for re conditioning, but here are the suspension linkages, all powdercoated with new shiny bearings and seals. I almost killed the powdercoater, as he didnt bung up any of the holes, so i have had to scrape them out, back to the original size so the bearings would fit, also I have had to re tap all the threads on the frame as well!!!
Ok, now for the embarassing bit, I really cant remember which way around the tie rod holder goes, nor can i remember where these two components go... Any ideas??? Please???
Anyway, I will update you all as more work progresses... Next step is rolling chassis and then start bolting things back on...
Nate
Nate
- nate
Hi all,
Well, things are going great guns now! Got the frame back last night with shiny new headstock bearings in... The time now is 4.30pm and have just emerged from the garage with the following results.
The frame and wheels look quite good. Hopefully it should start to look better and better as I clean, polish and spray all the bits and start bolting them on!!!
The next couple of jobs are to finish polishing the forks and give them a coat of lacquer, then start reassembling the front end, maybe the brakes so I can toque the front forks up, and then the engine needs cleaning and inserting into the relevant space!!!
Nate
Nate
- SHimmer45
- corky
i use this company on Ebay..
http://stores.ebay.co.uk/Tek-Hardware_W ... esstQQtZkm
top service and good prices...
kr1s project wanted
aprillia rs125 track bike
03 r6 race/trackbike
dr500 flat tracker project
- nate
Hi all,
Bit more progress to show .... Hope it all looks ok to you lot... Any points that you want to make... Please feel free to heckle from the back (Col!!! )
Ok boring, but im pleased... I have stripped cleaned and recovered the loom...
Following on... Here is the rest of the bike... As you can see the Instruments, engine, carbs, throttle cable, HT side and the new shiny radiater at in
I'm dead chuffed with how the wheels look...
The internals.... Amazing how long it took to sand and paint all the rusty bits... Oh... not to mention freeing up the throttle cables so the carbs actually closed when you close the throttle
Shiny new radiator built by Newquay Rads... top job
Damn... just noticed the weeds need pruning...
So work to follow... Get the loom in place and plugged in to the relevent places...
I still need to take the front forks off and polish and lacquer them
Oh, and I still need to rebuild the rear shock.... (I decided to build the bike around it...) or buy a good condition unit...
Anyway, comments appreciated...
Nate
Nate
- rc46
Silly bits, She looks so clean, Id get the kick start polished up a bit, remove and replace the nylon brake line runners on the swing arm, and your getting the shock rebuilt??? get them to install a braided line from the resivior as the old rubber one is covered with a rusty spring...
Looks ace, Cant wait to sort mine out this winter, The engine is getting aqua blasted, New crank Barrels and heads new pistons, gearbox rebuilt whole engine will have new seals and bearings!! FULL race tune with BDK!!! Cant wait, hope it looks as clean as yours, Mind you gotta look better than it is now LOL
Well done looking ace!
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TZ250 N (to be restored)
1 x TD3 (being rebuilt)
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
Nate, why do we do this ,go into such detail. Youve got to keep these standards all the way through.We shouldn't be patting each other on the back .We should be giving sympathy.
never mind , Its looking quality
=D>
=D>
- nate
cheers gang... Thanks for the comments...
Points taken...
1) where do I get replacement brake clip holder thingies for the swing arm
2) already have the braided line for the shock... just waiting for the shock to be rebuilt or replaced... Ohlins.... oooh how many £££'s
3) as for the engine, well I have a spare... so I want to get this one running (i.e. the original) and while its running... Clean and tune the other... then do a straight transplant... Thats the plan anyway
I know about the level of detail... dear me... It took me 2 hours to finish the gear change lever.... Filing off the casting mark, then wet and dry, then polishing it to a mirror finish...
Anyway.... I will keep going... thanks for the tips so far
Nate
Points taken...
Nate
- nate
