Page 1 of 3
need a new front sprocket
Posted: Tue Jan 08, 2013 10:51 pm
by pepsi
Where can I get a new sprocket for my KR250?
Posted: Tue Jan 08, 2013 11:29 pm
by Bogan
If it helps your OEM part number is 13144-1113 which appears to be shared by the 1987 EX250-E Ninja (according to one Google link I found).
I can't find any other more current models sharing that part number using any of my usual web resources.
Maybe give your local dealer a call and see if that part number has been superseded with something you can order?
Edit: I think you can use one of these:
http://www.jtsprockets.com/catalogue/sprocket/JTF516-13
Measure up the one you have and see if it will fit?
Posted: Tue Jan 08, 2013 11:32 pm
by the KR kid
RPM have a chain/sprocket kit on eBay. It's in the UK, but might be worth contacting them to see if they'll sell you just a sprocket?
http://www.ebay.co.uk/itm/Kawasaki-KR25 ... 20bcc43e85
sprocket loose
Posted: Thu Jan 10, 2013 12:30 pm
by pepsi
I found a supplier ;the old sprocket is loose on the splines, is that normal?
Posted: Mon Mar 25, 2013 9:59 pm
by pepsi
the new sprocket came in wrong so back to the drawing board
Posted: Tue Mar 26, 2013 12:56 pm
by pepsi
It seems that they will not sell me a sprocket by itself or they do not have one at all,so their ebay ad might be wrong
Posted: Tue Mar 26, 2013 12:57 pm
by pepsi
anyone have a good used one?
Posted: Tue Mar 26, 2013 1:03 pm
by pepsi
looked it up ,doesn't look the same
Bogan wrote:If it helps your OEM part number is 13144-1113 which appears to be shared by the 1987 EX250-E Ninja (according to one Google link I found).
Posted: Tue Mar 26, 2013 8:21 pm
by Top-shaggy
May be worth posting some pictures of your old sprocket - it may help us identify another the same.
Just a thought though... Is the old sprocket the right one for the KR250A ? Or has someone used an alternative? ( you say it is loose on the splines, worn? Or not the right one?)
Posted: Tue Mar 26, 2013 8:54 pm
by Howie
wemoto.com list them,
Kr250a front sprocket, looks like you have a choice of makes too.
Posted: Tue Mar 26, 2013 9:16 pm
by pepsi
thats a good question since I have H0nda wheels
I'll have to dig into it somemore
Top-shaggy wrote:May be worth posting some pictures of your old sprocket - it may help us identify another the same.
Posted: Tue Mar 26, 2013 9:51 pm
by pepsi
the dimension in this photo "21.6mm" is not correct for our bikes it is 24mm
The dimension in this photo "25mm" is not correct for our bikes it is 28.5mm
we have 12 splines not 13
Posted: Wed Mar 27, 2013 12:22 am
by ozzy1
Posted: Wed Mar 27, 2013 1:10 am
by Top-shaggy
I would email or phone them first to check
1. It's what your after and
2. They have it in stock
I've used them before and was happy with service
Posted: Wed Mar 27, 2013 2:47 am
by ozzy1
Nearest i can find to the dimensions you gave is for a GPZ900 but its a 530 pitch.
http://www.wemoto.com/bikes/kawasaki/gp ... eeth_-_jt/
