Page 1 of 2
dave i need info on them res chamber spacers packers
Posted: Sun Mar 10, 2013 12:12 am
by fred
prescott`s got 2 slow corners and i want to do me best ,have you any off the top of your head thickness wise measurements to space em out by ,
Posted: Sun Mar 10, 2013 1:37 am
Hi Fred
What effect does an increase in the volume have?
Posted: Sun Mar 10, 2013 1:58 am
by Top-shaggy
I've got them for the KMX200 - they are 6mm thick spacers.
They improve low down grunt without compromising the top end
Posted: Sun Mar 10, 2013 2:21 am
Thanks Shaun
Posted: Sun Mar 10, 2013 2:51 am
by fred
cheers f info ,ive got some 4mm ,so ile try 4 n 8 round lanes n on airfield fost
Posted: Fri Mar 15, 2013 11:26 pm
by dave32
I havent measured them,at a guess there around 8mm deep,they helped at low revs (below 8000rpm) when pulling out of a hairpin or similar.
I also run a 13/41 gearing for somehwhere like mallory,saves having to use 1st which is too low on most gearing for track use.
Posted: Thu Mar 21, 2013 11:54 am
by James P
dave32 wrote:...they helped at low revs (below 8000rpm) when pulling out of a hairpin or similar...
Dave, did you make these spacers yourself, or are they a commercially available item? I'd certainly be interested in trying some of these for road use, assuming there are no adverse effects anywhere in the engine speed range below chamber closure.
Thanks & regards,
Posted: Thu Mar 21, 2013 2:22 pm
by dave32
They were a set of spare standard chambers that i modded,not aware of any "already made versions" but im sure a decent local engineering firm could knock some up out of alloy.
no adverse effects form what ive experienced,once there closed off at the top end its the same as before.
Biggest difference for cheap outlay though is dropping a tooth on the front sprocket to a 14,allows the higher gears to be used and still good for over 125mph.
HTH
Dave
Posted: Thu Mar 21, 2013 3:05 pm
by scooble
has anyone got the specs/drawings for these spacers?
Posted: Thu Mar 21, 2013 11:28 pm
by Top-shaggy
These are the KIPS resonator spacers for the KMX200
Produced by a number of companies including BDK
http://www.ebay.co.uk/itm/KAWASAKI-KMX2 ... 589d77fb86
Shouldn't be hard to make ones for the KR
Mine on the KMX are 6mm thick
Posted: Fri Mar 22, 2013 9:17 am
by James P
dave32 wrote:They were a set of spare standard chambers that i modded,not aware of any "already made versions" but im sure a decent local engineering firm could knock some up out of alloy.
HTH
Dave
Thanks for the info Dave. I'll try making some spacers from gasket patterns! About 10-15 years ago, I had things like this made by a local firm which used a water cutter. However, I think they've now moved or gone out of business - I'll do some research.
Posted: Fri Mar 22, 2013 9:02 pm
by dave32
Well i was a bit far off with the guess in size,there actually 14mm thick which is nearly half the width of the stock chamber again.
I dont think a 6mm spacer will have much impact,but i maybe wrong.
HTH
Posted: Thu Apr 04, 2013 12:50 am
by fred
glad i havent made much headway on the things apart from finding a few abrafile blades ,ime going to cut up n mill some spare res chambers. 14mm it is then ,can always take a bit more off later ,free dyno friday afternoon
on 145rd`s now, its cold n fresh ,stutters at 9 grand ish then clears ,plugs are still matt black ,ime going to put the normal 135`s in tommoro and do a few runs and see what that looks like
Posted: Thu Apr 04, 2013 8:59 pm
by fred
done the spacers and jets ,its improved things all over,well happy
Posted: Thu Apr 04, 2013 9:34 pm
Photos of your spacers Fred
