vacuum pump
Posted: Sat Mar 16, 2013 11:36 pm
by gary
Hi, thinking of buying a vacuum pump brake bleed kit, does anybody know if they are any good, has having a mare bleeding my brakes.
Posted: Sun Mar 17, 2013 12:10 am
just buy a surringe, it does the same and costs only 0.50 £
Posted: Sun Mar 17, 2013 8:36 am
loosen the union at the master cylinder and make you get all the air out up there first.
Posted: Sun Mar 17, 2013 10:44 pm
by dave32
Hopefully its not but sometimes it can be the master cylinder seal leaking internally.
It doesnt show up until you try and bleed the brakes (was working fine before) then you spend hours and get nowhere,ive had it a few times with various bikes and its always been that,it shouldnt be too hard even with an empty system to get lever pressure even using the old "tube in a jar" method.
