setting carbs
- martin
thanks guys for all your help, and thanks to rc46 for phoning me and giving me advise, i phoned stan stevens today, he says standard jetting is fine, 38pilot,135main,he says lean the clip up to the 2nd from the top[leaner]. i have tried that with the pilot screws at all different amounts and it seems worse, above 4000 its fine,but below 4000 its fluffy,if the throttle is pulled hard from tickover,it dies,i balanced the carbs as rc46 said,so am pretty sure carbs are near on balanced, tomorrow i will drop the clip on the needle to the bottom[richest setting]and play with the tickover screws to see if that helps,surly the extra 50cc would mean it would need more fuel.
- rc46
Is she ideling okay Now? Fluffy?
dose she settle down to an even tick over when you rev her?
Let us know how you get on..
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TZ250 N (to be restored)
1 x TD3 (being rebuilt)
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
the idea of been a bigger capacity needing bigger jets is a logical way of thinking and sounds the obvious solution to such changes but the kr was jetted rich to begin with as its a road bike and if it had ''on the edge jetting'' when new i dont think kawasaki would feel too keen on the idea of a warranty! back to the bigger capacity/jetting richer topic, the ypvs boys who use 28pkw carbs on there bikes with mild tuning still using an airbox tend to leave the jetting as per kr1 s with good fueling and no problems so what stan said makes sense if you go on what the rd lads are doing aswell. the kr has a larger airbox but that doesnt necceseraly mean it will be leaner as a result, in fact as elf has found out in the past it can cause the bike to run richer due to the change in velocity/airspeed. anyway, stan will of put you right im sure, all the best, matt
- rc46
Aye, he (stan) would be a bit stupid to recomend the same jets if it didnt work.. I like a safe bike, I have 145's in mine and she runs nice n safe!!!
Except when its spitting its Cir Clips out LOL
1 x TDR250 Black
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
1 x TDR50 Blue
1 x TZR250 3MA
1 x TZ250 3YL
- the-elf
do a search as I've posted the link to the USA site for the carb manufatures a few times before, on there is a chart to help you jet the carbs correctly. If its fine above 6K then the main jets arn't the problem as they only control fueling at very high revs.
personnal I would check to make sure your've not got a blocked or semi blocked pilot jet first. If Stan said that the standard jetting is right and your still having problems then it points to the carbs not being right and blocked jets and or floats ect. are quite a common problem.
- martin
thanks for all your help. have taken carbs apart again, and one of the pilot jets does seem blocked,could nt blow through one,i hope that is the problem, i am going to take my time and balance the carbs as rc46 said with new pilot jets at the weekend,still cant work out stan stevens saying drop the needles to 2nd from top[as standard is 2nd from bottom]but then again he must be right, does anyone know, does it richen or lean turning the pilot screws in. once again thanks to all of you
- mr_bungholeo
trust in stan...he knows his stuff...heard they need jetting down somewhere.....but as above...a rich mixture will only fowl plugs a lean one will melt your pistons...screwing out the pilots leans the mixture out n in richen's it...
danny harris.....R.I.P
gone but totally forgotten...
- the-elf
#When I was jetting the 35mm carbs I had a simular problem where the bike would tick over but then die when I opened the throttle. This was caused by the primary air screws being too lean. I had to screw them in another turn or so to get it running right.
