1 cylinder intermittent firing
Skinnybob46
Post by Skinnybob46 »
Hello, bikes runs, new plugs, leads, coils, RH cylinder firing about 25% of the time the LH cylinder is. Any ideas??
Re: 1 cylinder intermittent firing
Hi Bob,
Have you tried swapping over the leads to see if the problem moves to the other side?
If it does then the problem is the lead or the plug cap or the connection (ht lead to coil).
If not then the problem is not ignition (spark) related as it uses a wasted spark system (both plugs spark at the same time, but only one on the compression stroke is needed).
You will need to check you are getting fuel to the cylinder and that it has compression.
Has this just started happening?
Bernie 8)
Post by jarno »
Hello Bob,
There is a switch conected to the sidestand to prefent you starting the bike when sidestand is out.
Sometimes the switch is the problem and the Bike runs on 1 cilinder
As a start i would try turning in the idle adjuster screw in increments on that cylinder and see if it solves the problem (perhaps the carbs
need a bit of setting up)
Could also be a partially blocked pilot jet
Good luck
jarno wrote: Mon Dec 10, 2018 11:27 am Hello Bob,
that's not possible. only one pickup and one coil.
Skinnybob46
Thanks, I've tried swapping over the leads (I know it's a lost spark but did it anyway) and have tried swapping over the carbs. Any other ideas. Spent a lot of money and time to be tantalisingly close to completion!!!!!
2stroke
Post by 2stroke »
Did you find the problem ? I have one doing the same
