Wheels, shocks, forks, frame
Posts: 2120 Joined: Sat Jun 09, 2007 10:10 am
Post
by headcoats » Sun Mar 10, 2019 6:34 pm
Anyone fitted a 150 tyre and how much gap is left tyre to chain in mm ?
Also I know it's a 150 but could someone put the verniers across the broadest part please ?
I have machined 5mm off my sprocket carrier too for the LC build and fearing I won't have room
Posts: 3926 Joined: Fri Jun 18, 2010 11:29 am
Post
by Luders » Sun Mar 10, 2019 7:07 pm
loads of space Martin, I used to run them in 2011
Post
by headcoats » Sun Mar 10, 2019 7:11 pm
Cheers Luders but I have machined 5mm off the carrier , so the chain will be 5mm closer to the tyre
Post
by Luders » Mon Mar 11, 2019 9:31 am
Should still be okay, I ran 160's in a std swing arm on the bike you saw
Posts: 1593 Joined: Wed May 16, 2007 2:24 am
Post
by KR-1R » Tue Mar 12, 2019 7:36 pm
is a function of tyre brand which for a nominated size could be wider by +/- 10mm
and rim width - same for cars
being the running gear is in a different chassis/engine output centreline
if it doesnt fit then offset front sprocket and respace the rear to suit - that youve already done...
Post
by headcoats » Tue Mar 12, 2019 7:48 pm
Yes but with the puny LC chassis it's like threading a needle , hence the carrier being machined 5mm in so it misses the frame plate
I know a 140 fits but had a feeling with the 150 it may not
Post
by headcoats » Wed Mar 20, 2019 10:15 am
I have a 150 tyre here , not fitted to the rim and it measures 160mm across
That's why I need someone with a BT tyre fitted to give me the measurement please
Post
by Luders » Wed Mar 20, 2019 12:47 pm
On a rim it would never be 160
Posts: 1436 Joined: Tue Jul 25, 2006 8:01 pm
Post
by Garry » Wed Mar 20, 2019 1:13 pm
I have a BT090 150 section and edge of tyre to inside of chain is approx 12mm (can't measure exactly)
Hope that helps
Post
by headcoats » Wed Mar 20, 2019 7:17 pm
Cheers Gary
Well with my 5mm machined off the sprocket carrier then that measurement will give me 7mm clearance
How about cutting a piece of carboard 12mm wide and see how it sits between the chain and tyre
Thanks in advance
Post
by Garry » Thu Mar 21, 2019 11:21 am
That measurement should be good enough for what you need - it could have a 2-3 mm tolerance either way anyway depending on how accurately the wheel is lined up.
365motos
Posts: 8 Joined: Fri May 06, 2022 10:00 pm
Post
by 365motos » Tue Aug 23, 2022 10:06 pm
My track bike has a 160 on it and it's tight but there is plenty of clearance.
