The Hybrid
- mr_bungholeo
- the-elf
Nope both L and H models require the stem swap. The L uses bigger disc's though 310mm as opposed to the KR 300mm which are fitted to the H model.mr_bungholeo wrote:zxr400L models need the stem swapped..but zxr400h are a straight swap...but i never seem to see em on fleabay..only L models...
- the-elf
The rear 4.5" dymag I've got was bought brand new as an RGV rear. It can then either be adapted to fit the KR rear end or bolted straight in to an RGV swinger.corky wrote:still after a rear dymag 4.5 are rare as hens teeth and fetch good prices..
the zxr400 sp are the ones to get with zxr250 yokes as you dont need to swap the stem..gonna get my front forks rebuilt (zxr400l) and i think the elf or someone got the bottom adjusters fitted to std forks and a cartridge kit..
Strangeengine got his done by maxton and thought they were awesome!!!
Yep I got compression adjusters fitted to the fork bottom as well as a One off Ohlins cartridge kit. The are an awsome front end as well.
Red Devil 777
True, but I believe you can use the h yoke with a spacer fitted under the bottom bearing, like the lc boys do when fitting rgv front endsthe-elf wrote:Nope both L and H models require the stem swap. The L uses bigger disc's though 310mm as opposed to the KR 300mm which are fitted to the H model.mr_bungholeo wrote:zxr400L models need the stem swapped..but zxr400h are a straight swap...but i never seem to see em on fleabay..only L models...
- the-elf
- the-elf
May be as the H model stem is the same as a KR but just longer. Anyway its easier to just swap the stem, which takes 5 minites with a press.Red Devil 777 wrote:True, but I believe you can use the h yoke with a spacer fitted under the bottom bearing, like the lc boys do when fitting rgv front endsthe-elf wrote:Nope both L and H models require the stem swap. The L uses bigger disc's though 310mm as opposed to the KR 300mm which are fitted to the H model.mr_bungholeo wrote:zxr400L models need the stem swapped..but zxr400h are a straight swap...but i never seem to see em on fleabay..only L models...
mgtkr1
Red Devil 777
Agree 100%, but not everyone has access to the required tools (myself includedthe-elf wrote:May be as the H model stem is the same as a KR but just longer. Anyway its easier to just swap the stem, which takes 5 minites with a press.
To be honest I wished I'd known what you could and couldn't do with the various zxr bits and models before I purchased one of everything at some time
Anyway if I knew what I know now........
Zxr 250a yokes with h legs isn't a straight bolt in either, cos if you want to use the 3 spoke zxr wheel you'll need to possibly adapt the spindle as The centres on the 250 are closer than on the 400 and if you want to use a 1s 5 spoke you've got to sort the spindle out, as the hole in the fork legs is for a 20mm spindle and the kr uses a 17mm one and I'm pretty certain you can't do it by a bearing swap.
- corky
- the-elf
[quote="Red Devil 777Anyway if I knew what I know now........
I'm of to ebay to look for a zxr636 front
[\quote]
Not a bad choice at all. And fully adjustable with radial calipers as standard
[\quote]
- the-elf
[\quote]
[\quote]
- ScottaKR
Red Devil 777
I'll tell you when I've bought every bit going, could be sometime next year, then again it may notScottaKR wrote:What yokes would you need to use with the ZXR636 fork legs on a KR1 ..... ZXR250 perhaps?
And what size discs would you need to run with them?
I'd hazzard a guess at zxr250c yokes, but that's all it is.
mgtkr1
if anyones wanting to shift a usd front end that will go on a kr let me know as i will be after one in a few weeks, getting my trick shock first!! was trying to avoid a usd f/end in favour of a fzr rrsp but the fork diameters are diffrent anyway(thought they were the same as kr) and i hear nothing but good things about the zxr setup. looks good an'all
