Does anyone recommend any Reeds - for top end performance rather than low revs. I dont think the standard ones are bad, just that I have to get some and the plan is to race the bike with pressurised airbox.
Reeds
- SHimmer45
mj43
We tested a number of reeds and stock were best http://myweb.tiscali.co.uk/teamsparrow/dynoday1.htm
Having said that I am now running a set of v-force 3 reed blocks off a KDX200.
reed cage is the same - making up a stuffer was a little tricky needed two stuffers cut in half to make up one with the hole in the centre - KDX carb comes in at an angle.
It feels like this set up gives more power - needed rejetting up two jetsizes and the needle needed richening up.
KwakOn
mj43
No they are complete new units not cheap can be got locally or if from states add 21% duty
http://www.motoworldracing.com/v-force-3-mx.html
