What do you make of this rattle then?
I hope you can tell which rattle im talking about....
In each of the vids i've made the noise in question occurs at idle and up to roughly 4-5000 rpm, then i cant hear it over the engine note.
It can be mostly heard as the engine slows to idle speed after each blip of the throttle - i took the generator cover off to check the flywheel is still bolted to the crank and it seems ok but i also noticed the noise increased when i did this leading me to think that perhaps its from the balancer shaft??
Anyway enjoy the show
These videos are via Photobucket and are a bit slow and jerky to say the least.....
