rgrds..........Dave
Red Devil 777 wrote:I agree with Mike, always had fun getting them to bleed up, I always resorted to the old trick of running two pipes from the bleed nipples to the reservoir, cable tie the lever back and go for a brew/kip/night out.Come back later and jobs a good 'un.
Do it the way I said and you'll find it a piece of piss, all you need is some line suitable to run from bleed nipple to reservoir, and if you're struggling for that I'll even post you some 'cos I've yards of it spare (I use it on pub irrigation systems and it comes in 100m rolls!)headcoats wrote:I will be doing the same shortlySHimmer45 wrote:gonna be in for some fun when i bleed my brakes then..... o the joy
Yes you can, Hel will even make you custom lines to your spec for the same costs. Cause I use a radial master cylinder on my ZXR400 front end I needed slightly longer lines with a different thread on the banjo bolt and they made them up for me for the same price.666damned wrote:thanx for the reply's guys...........i'll get some braided hoses on my crizzy list.........can you get Hel lines for the KR1?......and i'll also get a syringe kit bought as well,..............
