What diameter are the KR1S forks !!!
Wheels, shocks, forks, frame
I don't have the bits here to measure but i'm having some headlamp brackets made and need to tell him the diameter of the stanchions :oops:
thats a bit fresh out
aye up,i just measured mine 40.5mm with a mitutoyu dial verniur,hope this helps cheers fred :oops: #-o
41mm :idea:
Cheers :mrgreen:
col
Re: thats a bit fresh out
Post by col »
fred wrote:aye up,i just measured mine 40.5mm with a mitutoyu dial verniur,hope this helps cheers fred
I think you either need new glasses or new verniers. :D
KR1 and 1S forks are 41mm diameter
Post by SHimmer45 »
col wrote: I think you either need new glasses or new "very nears". :D
*just fixed that for you Col :mrgreen:
#-o your dead right lads,there was a bit of grit in the rack on me verniers,glad there not the ones i use at work
