oil amount, zxr400 forks (h)??
Wheels, shocks, forks, frame
mgtkr1
Post by mgtkr1 »
anyone know the std oil amount that should go into zxr400 forks??? thanks in advance, cheers matt
kwackman12
Post by kwackman12 »
Great site here Matt http://www.zxrworld.co.uk/zxr400/main.htm should find all you need on there
Gary
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
mgtkr1
Post by mgtkr1 »
cheers mate, known about this for some time!! cant beleive i didnt have a butchers before posting!! ah well thanks kwakman.
kwackman12
Red Devil 777 wrote:Standard is 424ml +_2.5ml, viscocity sae5w, oil level with compressed spring 85 plus or minus 8mm below top of outer tube.
Run mine standard on the kr, would have thought you'd be ok with that for a start in the project :lol:
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
mgtkr1
Post by mgtkr1 »
perfect. have found that ive bolloxed the new seals ep and one side is leaking!!! will put tape around the edge near the top this time as i beleive this sharp edge has done the damage. good job i have spare set and didnt wait till the night before pb trackday to fill em up with oil!! ah well, cant you tell its been a long time since i replaced fork seals? thanks for that anyway. =D> will try again saturday.
DAMO666
Post by DAMO666 »
I find the old plastic bag technique works every time, place a plastic bag over the open end of the fork leg and pull it tight, oil the inside of the seal, it should them fly over the undercut in the fork leg without tearing the seal.
1990 KR1S
