Is there anything i can do about this ?
Weeping Nipple !!!!!
One of the front KR1S calipers on my Hybrid is weeping throught the threads
- kwackman12
been searching the archive on the RD site about this and as i'm using S/S bleed nipples i had from Hel brakes this may be a problem
The angle on the taper is not quite the right ??????
Should i get some Kawa genuine bleed nipples to try ?
Then saw some of thes speed bleeders type and they have a coating on the threads
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0049787355
http://www.mandp.co.uk/productinfo/5160 ... es/Russell
Plus these look like they have a rubber type sleeve on the threads
http://www.demon-tweeks.co.uk/products/ ... GDRBN704SB
rgvlee
The speedbleeders come with a coating on the thread to help them seal. They are very good, I run them in my bikes, the make bleeding the brakes a very simple task. The only thing I have heard bad about them is that they can break if you overtighten them.
In the past I have used PTFE/plumbers tape to make the seal. Done it on road and race bikes.
