Ok my best as of Nov 2007
Flowed and filled cases.
KIPS and main exhaust up 1mm, KIPS are about 3mm wider
Transfers up 1mm, main transfer nearest exhaust tidied up, rear transfer significantly wider (ring webs between main transfer and boost port about 2mm thick) runs TZ pistons with ring groove in the boost port. Barrels matched to the cases, KIPS ports matched to the power valves. Head matched to TZ piston domes, Barrels shortened 2mm and strengthened to run 3TC pistons, V-Force 3 reed blocks.
Lomas pipes, 35mm carbs, running airfilter in a modified standard airbox, air feed from over the rad, rad dropped to allow feed.
Reading on a Dynopro dyno where a stock KR1S makes 50hp. Bonneville bike made 56hp. This engine at 64hp is 14hp (28%) up on a stock KR-1S engine.
Engine is 14hp up on a stock KR-1S
