the KR-1S SP's (C3A) used a skimmed head raising the CR to 8.0 (7.4 is normal)
Corrected CR vs Uncorrected CR
?? SP were slightly higher in exhaust port and running shaved head ??
treat 8.0 as fairly arbitrary
aim for between that, for a maximum and back down to Standard after acheiving
correct squish clearances.
>>> 7.4 ....Scooble....... 8.0 <<<
Theory is one thing - but actually measuring what you have (+/- all the scientific errors of each measurement) versus what will have to get to gets fiddly when youre dealing with domed pistons, chamber volume, spark plug recess/volume...
Which is why most people just settle for achieving correct squish (simple assemble, measure, then subtract appropriate thickness of material)
?? consider also the effect of CR on engine braking on closed throttle at high revs (cushioning effect) - how many HP benefit %, would it make on Avgas etc vs limiting chance of detonation from octane and added heat.
I guess the characteristic you want to achieve is, clean burning, efficient and reliable over outright power.
TSI might have alot more input. (??he had a story about formula racing and head measurements??)
MAXIUM SQUISH VELOCITY more important than CR?
http://home.earthlink.net/~scloughn/id21.html
http://home.earthlink.net/~scloughn/id16.html
http://www.bridgestonemotorcycle.com/do ... ssion6.pdf
The effect of higher compression ratio on fuel consumption and power output was investigated for an air-cooled two-stroke motorcycle engine. The results show that actual fuel consumption can improve by 1-3% for each unit increase of compression ratio over the compression ratio range of 6.6 to 13.6. The rate of improvement is smaller however as compared to theoretical values. The discrepancies are mainly due to increased mechanical and cooling losses, shortcircuiting at low loads, and increased time losses at heavy loads. Power output also improves, but the maximum compression ratio is limited due to knock and the increase in thermal load. In addition, the investigation covered the implementation of higher compression ratio in practical engines by retarding the full-load ignition timing.
FACTORS LIMITING COMPRESSION RATIO
Higher compression ratio makes it possible to improve power output., but causes serious problems such as knock and piston thermal load increase. To solve the problems, several reports have proposed low compression ratio at high-speeds and heavy loads with variable combustion chamber
volumes.(6)(7). In this paper, retarded ignition timing is discussed as a remedy for the problems.
... leads back to the ??shortlived?? early 90's GP designs that had gas chraged floating heads/chambers ... so higher compression at low revs ... lower compression at higher engine speeds and loads.
