I have had loads of trouble setting mine up especially low and midrange
It has always screamed off in the powerband but light throttle was always compromised by something.
Just got this off the RD site
QUOTE
hello,
tobster,
JJH and N68X are the same I believe
Here are the specs for JJH and N68A which is fitted to the KR1
JJH
J = 3' 00' Taper Degrees
J = 25.40 L1
H = 2.435 Dia
N68A
A = 1' 35' Taper Degrees
H = 24.25 L1
R = 2.75 Dia
Seems to be a fair bit of difference
Now does anyone have the low down on what is the equivalent of a replacement needle ?
I ended up running (YPVS 350 engine)
#152 main (premix)
JJH needle clip 5 (richest) (will not run on anything less)
#45 pilot jets
airscrew 2 turns out (i know)
Ramair filters.
Allspeeds with detachable end cans
Mick Abbey Tune
V force 3 reeds
I went to #160 mains in the summer and lost 4.5 BHP and it wouldn't rev over 9 grand,so went back to 152's
Anything less than #45 pilots i get a horrible jerking on light throttle and only going up on the pilots seemed to cure it
But i guess the thing i need to know is about these fabled JJH needles
