Engine using gearbox oil
Glyn
Post by Glyn »
Hi there, can somebody advise me on the KR-1S problem I have. The bike is smoking on one side and I believe/told that a leaking crankcase seal is causing the problem.
Is this a common problem and is it an easy fix
Thanks for your help
Regards
Glyn
Post by scooble »
Not a common problem, but it does happen.
The crank will have to be stripped. Seal and bearing kits are a reasonable price.
http://www.pjme.co.uk/acatalog/Kawasaki_KR1S.html
But the rebuild can be expensive
