kr250 fuel tap
dougindoors
kr250 fuel tap
hi any one got a spare fuel tap or the spring washer that goes between the plate and tap face ??/ cheers
1984 Kawasaki KR250A
2 Smokey and they bandit
dougindoors
fuel tap again
ok then, does any one know if there are any alternative taps for the kr250.
the gpz500 or ex500 looks the same, but does anyone know if the mounting holes are the same hole centres. [-o<
- ScottaKR
Well the KR1/1S tap is almost identical, and most all parts from it are interchangable, so you could ask in the parts wanted for one from a KR1/1S. This also means that any tap that fits the KR1/1S will also fit (theoretically) the Tandem Twin, if that helps.
KR250 Tandem Twin (Naked)
dougindoors
tap
cheers scott rgds doug
250 drummie
dougindoors
fuel tap
just for the record the kawasaki ex500 and gpz 500 taps fit kr250's you just need to drill out for the 2nd outlet, 2nd hand and in good condition £10 =D>
