1989 kr1 with kr1s bits and bobs
maccas
maccas
maccas
Janbros i have changed the way that the valves work so that the inner and outer valves rotate in opposite directions to each other and then i have swapped round the f3 style powervalves accordingly so they all line up better when the valves are open and also when they are closed.
I will draw a diagram later to demonstrate
maccas
ok i will try and explain, using just one barrel as an example
The standard powervalves (not f3 style) turn the same rotational direction as each other in each barrel. So when in the open position the kips chamber is shut off and there should be a nice smooth passage along the auxillary exhaust passage and into the main port. No problems apart from it makes setting the valves up a bit tricky.
The f3 valves are handed, so 2 left hand 2 right handed. I get the impression that you are supposed to put the 2 left hand valves in one barrel and the 2 right hand valves in the other. If you do not do this and put one left and one right in each barrel when the valves are in the closed position only one auxillary port gets closed off. When the valves are in the open position everything lines up lovely and there is nice smooth ports for the gas to follow.
I have fitted one left hand valve and one right hand valve in each barrel then fiddled with the linkages so that each pair of valves (each barrel) turn in opposite directions to each other, this way, when open things are lined up nice and smoothly and when closed both sides of the port are closed properly.
Hope that makes sense.
maccas
Now I am confused
When the engine is stopped or at low revs what possition should the valves be in?
Both closed, so the port leading to the resonator chamber and other side port leading to the additional exhaust transfer port in the barrel are both shut?
Or both open?
Or one open and one closed? if so which?
Or both open?
maccas
maccas
Just had another look and getting more confused (Friday, long week, beer....)
The outer port (on the side where the resonator is) has two positions, one which opens to the resonator, and the other which closes the port to the resonator and opens the transfer port to the cylinder.
The inner appears to only have one function...open and close to the transfer port in the cylinder.
I will have to put the linkage on and see what happens
