KR1 Restoration
Not sure if you've mentioned it or I've missed it but are you going to put the 'luggage' brackets on it?
Post by Bertie_Mollie »
Howie wrote:Not sure if you've mentioned it or I've missed it but are you going to put the 'luggage' brackets on it?
Yes, they'll go on when I get round to sorting through what I have.
Andrew
GWB KR1s C2 - Now gone :-(
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT :shock:
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
Looking nice there Andrew 8) =D> .
Swing arm built up and regulator plate fitted.
Last edited by Bertie_Mollie on Fri Dec 22, 2017 11:57 am, edited 1 time in total.
dandan0162
Post by dandan0162 »
me like where this is going =D>
Nice work Andrew it's come on a long way since I saw you last.
Clocks built up with powder coated clock and main fairing brackets.
Also fitted a NOS speedo which I have had for some time. I can't think when would be a better time to use it.
KFOR
Post by KFOR »
That all looks like its straight out of the factory :shock:
Original bolts and everything =P~ .
Keep the pctures coming Bertie :D .
Very nice 8)
Keep the photos coming =D>
Now that is mint in the true sense of the word
garye345 wrote:Original bolts and everything =P~ .
Hi Gary,
Yes, I'm going to try to keep the fixings original everywhere :shock:
Andrew
Hi All,
I haven't updated for a while :oops:
Not been getting a lot done as I keep getting distracted with other projects :roll: .
Anyway, wheels powder coated, bearings fitted, tyres fitted and minty front KR1 discs fitted \:D/
Also got my standard rebuilt shock back which is nice.
Next, need to get my stanchions re chromed, forks rebuilt and then I'll be on 2 wheels :D .
BM
Last edited by Bertie_Mollie on Fri Dec 22, 2017 11:58 am, edited 1 time in total.
SP_BOTT
Post by SP_BOTT »
Ooohh, tell me about the shock now please, where, how much and how long did it take?? I've also realised what that plastic cover is on my bench now, does it go over the shock adjuster??
SP_BOTT wrote:Ooohh, tell me about the shock now please, where, how much and how long did it take?? I've also realised what that plastic cover is on my bench now, does it go over the shock adjuster??
Hi Paul,
The shock was done at Mick Gardener Racing in Barnsley. It took a couple of weeks to turn around. I had the spring powder coated and I think it came to about £130.
When I went up there I took a few shocks with me that I thought had good piston rods but on close inspection they were pitted. They replaced some of the internals with new parts.
Yes the black plastic piece is the shock adjuster cover.
BM
