engine number kr1s?
rickychutney
- Newbie
engine number kr1s?
Hi Chaps
looking at purchasing a kr1s on a j plate however the engine number is kr1250c000029 with a frame number of kr250be002499. im a little suspicious that this may not be an kr1s but just a kr1 as the numbers are low. how can i be certain it is a kr1s
cheers
ricky
cheers
ricky
- ScottaKR
Hi Ricky, and welcome to the forum.
You seem to have gotten your frame and engine number swapped around, and that 1 in the frame number dosn't belong. Aside from that though, the c in the frame number after 250 means that it's a KR1S. Dont wory about the engine number having a b in it after the 250, as kawasaki numbered all KR1 and KR1S engines this way (although the engine number does seem a little low to my mind).
By far the easiest way to tell a KR1 and a KR1S apart is by looking at the frame. The KR1S main frame spar has smooth sides, while the earlier KR1 has ribs running down it's length.
KR250 Tandem Twin (Naked)
rickychutney
- Newbie
- ScottaKR
The gearbox oil filler cap is the easiest way. The KR1 had an alloy cap with a slot in the top that requires a large screwdriver (or even a coin) to open it. The KR1S oil filler cap didn't require a screwdriver or such, and could be opened by hand.rickychutney wrote:Thanks alot for that, is there anything visual on the engine which would indicate either model.
rickychutney
- Newbie
Thanks jarno for your input, i got the engine nr and frame nr the wrong way round in my original post, however what do you mean when you say screw the combustion chambers open. where are these numbers and if i go to look at a bike to purchase i dont think i could start taking it apart javascript:emoticon(':D').
in the upper cowling you have inspection panels,if you screw them of (will take you 1 minut) you will look direckty at the cilinders you also can see the combustionchamber on the cilinder screw them of (2 bolts ) behind them you will see the numbers.
check the numbers and you will know if the are kr1 or kr1s cilinders.
rickychutney
- Newbie
rickychutney
- Newbie
- tescr500
http://www.ebay.co.uk/itm/1992-KAWASAKI ... 2a17e3550a
i take it that was the one you were looking at what was the body work like, that alone is worth its weight in turnips, but don't look like a 3 grander then cheers
