Right if i have a 1.80 thick 0 ring do you need to cut a groove 1.20 deep to get an effective seal ?
Also true or false do you need to compress an o ring 45% to seal properly ?
As I understood it, the gas pressure is sealed by the head to barrel, not by the O ring itself. The O ring even if made from Viton will stand only around 260C, the gas temperature is way higher than this, so if there is any sort of gas to O ring contact it will burn/damage the ring.headcoats wrote:Thing is it's the combustion 0 ring that is the important one which has to handle the pressure,so how do i get around this
