Mitaka and Vertex Pistons DT 125
maccas
Hi guys I've done a search but I just want to confirm.
The mitaka pistons sold for the kr1s are just re-badged dt 125 pistons with 4 holes drilled in them is this correct?
Because the holes have been drilled in them this would be why kr1 mitaka pistons are more expensive than mitaka pistons for the dt 125 ?
If this is the case I will buy dt 125 pistons and drill the holes myself.
Also I have noticed that PJME stock a vertex piston for the dt 125 too:
http://pjme.co.uk/acatalog/Yamaha_DT125 ... p_End.html
Now I would much rather run a vertex than a mitaka as I know they are a quality piston, I rang up to ask if they had experience running the vertex in a kr1 and they told me that the piston height is different and it won't fit, they didn't tell me by how much or anything.
I don't believe that it won't fit, if a mitaka dt 125 piston fits, why won't a vertex one?
Also would the vertex pistons rings be ok running on a plated bore when the the dt 125 has a cast iron liner?
if I'm not mistaken, Vertex piston's are made by Woessner ...
Mitaka dimensions can be found here : http://www.mitaka.co.uk/PISTON%20DATABA ... Page3.html
alternative pistons
some pics here (if you havent seen)
http://kr-1s.co.uk/forum/viewtopic.php?p=55490
KDX125 vs KR-1
DT125... seems better alternative than KDX (longer skirt, drill some lube holes)
Mitaka...
Vertex...
...looks to be cast therefore not made by Woss?
the Mitakas have that galvanised/eutectic, dull as cast, look - the Vertex reflects light so the skirt machining might be better for lubrication (and wear appraisal - tiny ridges)
KDX125 vs KR-1
Mitaka...
Vertex...
maccas
Yep the vertex piston is a cast piston with a high silicon content. They are a very good piston. Ktm use them as their oem piston in their bikes.
I have seen the troubles of ring pig location with the wossners so i would like to avoid them.
I will order 2 vertex's and give them a try,i have a dt125 prox piston here that i can compare with.
- Top-shaggy
maccas
Hi guys,
Just spoke to TWS GB who are the UK suppliers of vertex pistons, they can get the vertex piston for the DT 125 in a 56mm size, 0.5 oversize, 0.75 oversize and 1.00mm oversize.
They are currently out of stock on the standard bore 56mm piston but he usually keeps them in stock and will have more in 2 weeks.
I asked him what price they are and he said 74.95 but that was a quick calculation he did there and then, by the sounds of things I think if we ordered a very large number the price would come down.
I will happily be guinea pig for these pistons and give them a go in my kr1 barrels.
Here are a few close up pics of the piston stolen from the tdr forum:
This is a 0.75mm piston but the 56mm is the same design just smaller. I asked the man at TWS if the rings will be happy running on a plated bore instead of a cast iron bore (that the DT has) and he said yep it will be fine.
I need to find out whether they need to run a 19.5mm wide small end bearing or a 17.5mm small end bearing, both sizes are easily available but just need to know which one is needed.
Information on the tdr forum suggests that a 17.5mm wide small end is needed whereas info on the PJME website suggests that a 19.5mm wide small end bearing will be fine.
Only one way to find out......
Also i remember reading that 3ma pistons fit the kr1 too, I have 3 3ma pistons and a dt125 mitaka so I will be able to compare all of those plus the vertex and the original kr1 and the later kr1s piston. I will join all 5 of them by the pin so we will be able to see the differences.
maccas
maccas
Dug out a 3ma piston and the prox/mitaka dt 125 and marked the ring peg locations on the crown and put them into a worked barrel:
Prox
3ma
The rear port has been widened on this particular barrel but the rings are still just about ok, single rings on this barrel would be better though I think.
Anyway so the vertex ring peg position should be fine, will just have to compare compression height and check squish.
Prox
3ma
john-b
If it helps i had a kr that had been sleeved and ran TZR 2MA pistons so yeah it should work fine. I suppose if you needed a replate you could use 2.5 oversize to increase capacity too although im not sure.
Let us know how you get on with them as i have some barrels that need a replate so i might try the over size option which would be about 270 at a guess i think?
I wish i knew something about KR's so i was like knowledgeable about them and everything like what you lot are
Vertex piston
so how come PJME sell them for £56.95 + VAT (£68.34)maccas wrote:... spoke to TWS GB who are the UK suppliers of vertex pistons, and he said 74.95 but that was a quick calculation he did there and then
maccas
maccas
maccas
maccas
TwoStroke Institute
