I remember you talking about that familys garage Only progress today has been arrival of a head. looks to be in tip top nick so all good. A vast amount of what i have is filthy and in need of a deep clean. ill pick up some engine cleaner from work and get started . Does any one have any recommendations on a decent priced ultrasonic cleaner ?
IF IT DOESNT MAKE IT FASTER LIGHTER STOP QUICKER OR BRING ME SEXUAL SATISFACTION IM NOT INTERESTED!
Been out having a bit of a clean up and the standard pipes i have are ok. they have been chromed and a bloody good amount of that has come away . i dont like it and want them back to standard for one of mine. I have a set of standard 1s pipes with aprilia rs cans on which will clean up ok for one of the others so can anyone recomend a local company to put my pipes back to standard black. clocks are rusty and dented so lots to do their . one frame has been polished and is suffering a fair few scratches and nicks. in fact its a bloody mess as clock mount has been smashed off too. Didnt notice that till i got the autosol out . arse.
Im not sure alot of company will chrome used pipes as they dont like all the gunge/carbon crap in there acid tanks.
If you se the S pipes and prilia cans make sure the Internal diameter of the baffle and spout are Larger than the S stinger outlet,if there not you could run into overheating problems due to excessive back pressure.
ATB
Dave
done a bit but not much just cleaning of frames and brake calipers. mostly been buying stuff on evil b im afraid. got a front brake set up and am awaiting some body work to arive at castle collins once it does and is cleaned up ill post more pics. The one tank i have is dented and scratched deeply on one side so ill be startng that at the weekend. All three frames have clock mounts broken off so ill need to get measured up and have someone weld me some fresh ones on . ill use work time to source a local firm.
6 birthday for our oldest boy today and i came in from work to be told dont worry daddy their is a present for your bikes in the garage. bless him. so yep i sneaked off and standard rear seat section has arrived , side panels and belly pan are on their way . funds havent stretched to a fairing yet but ill be building another red rocket by the looks of it
