My engine is being rebuilt at the moment and I need some new bearings for the balance shaft.
I admit I haven't tried my local bearing supplier yet, but with these having a locating pin I get the feeling they may be difficult to get.
Has anyone got any info on these ?
Bert
Balance Shaft Bearings
- Bert
mj43
buzinc
balancer
If its any help.
I had an RD250 air-cooled twin crank rebuilt 6/7 years ago, and the re-builders drilled and put pins in the main bearings. They ground down the original pins and re-drilled in new ones at a different part of the bearing. When I enquired why, the reason was the original pins sometime start to rotate in the crankcase half's!
But what I'm saying is, new pins can be done!
Dont mind be corrected on this one, but I have not known anybody having to replace these bearings!
Have you looked at this link?
viewtopic.php?t=8284&highlight=balancer+shaft
buz
buz
