Wanted - KR250A (Tandem) Mechanic East Coast Australia
Bogan
Post by Bogan »
As seen in my thread over here, my KR250A runs, but it runs very badly.
Here it is running:
http://www.youtube.com/watch?v=aENRmGMoXMw
Here is what I would like it to run more like (this bike is not mine):
http://www.youtube.com/watch?v=hXlrbYV-2dY
Can anyone in Australia recommend a workshop/mechanic/backyard enthusiast preferably in NSW/VIC who knows more than the average about tandem twins and might want to take on making this engine run better?
Once it runs properly then I can do most other things myself (making things pretty, replacing chain and sprockets, brakes, suspension, tyres etc.) but I don't want to throw away any unnecessary funds on something that doesn't run.
Any help would be great.
Even if you are a bit of a DIY demon if you are confident I would be willing to discuss options.
Tony
Richie Rich
Post by Richie Rich »
Hi Tony, you could try Deet at RGV Spares in Melbourne. He rebuilt my RZ350 engine a few years back and was awesome to deal with, very knowledgable on two strokes and good value. Yes he's Suzuki biased and I can't say for sure whether he knows much about KR's or can take on your work but might be worth making contact. He works on bikes from his home workshop.
http://www.rgvspares.com/index.php?opti ... t&Itemid=3
1983 RZ350K
1984 KR250A
1985 GSXR750F
1989 TZR250 3MA
2010 Street Triple 675
I remember that video from when you first posted it. Unfortunately, I don't know of any mechanics that know these bikes well, so I worked on mine myself (with varying degrees of success :roll: )
What have you tried on it so far to get it running right. Definately sounds like it's only running on 1 cylinder (which has sometimes been atributed to the crank dampers not being adjusted, but that's the last thing youd want to try as its a pita).
Have you checked for spark? (could be faulty CDI, coil, lead or plug, or even a badly adjusted pickup coil air gap).
Does it have good even compression on both cyls?
Is it getting fuel to that cyl? (carb could be clogged up, bad inline filter...)
StrokerBoy
Re: Wanted - KR250A (Tandem) Mechanic East Coast Australia
Post by StrokerBoy »
Bogan wrote:Here is what I would like it to run more like (this bike is not mine):
No, it's mine ! :lol:
If it's any consolation, it doesn't start like that every time. Far from it. I've been known to sit there kicking it for 10 minutes with no success. :oops:
Once it's actually running on two, it's fine though. :D
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
250 drummie
Post by 250 drummie »
Just give it a go yourself, no one has a clue anymore and they don't give a crap either. If they can't plug it in their lost ](*,)
250 drummie
Have a go at the fuel system first, clean out the tank (and tap filter), chech and clean the carbs......process of elimination, then check your ignition, plugs, coils, lead/caps, cdi. Then post for more help with the difficult mechanical bits.
Good luck :D
dougindoors
running on 1
Post by dougindoors »
always start with the ignition system, have you got a spark? if so then give the non firing cylinder a sqirt of carb cleaner down the carb, does it fire up? then its a fuel prob.
1984 Kawasaki KR250A
2 Smokey and they bandit
dougindoors
troubles
put me and my wife up for two weeks might be intrested in sorting it for you, lol. only thing is dont like them dammed spiders you get over there
