si.likes.guiness
Post by si.likes.guiness »
thanks mate :D
ive seen more tarts than mr kipling
hi ben ,are you still going to do a fibreglass cover from that steel lid :?:
and jumping threads a bit ,is ther any hollow axle n swingarm shafts out ther that could be made to fit ,or do it the old fashion way ,
Yes I'll document the fibreglass process here for the tank shroud.
I think from an engineering perspective, axles need to be solid steel.
marksim
Post by marksim »
Just read all this so far and well done.
Bikes hopefully gunna be a winner :)
KR1S Special
Aprilia RS 270
Suzuki RGV VJ 21
Yam RD400F
KTM SDR 990
you're gonna keep the kick start?
how about an alloy one off a KX or something (125's are stubbier)
don't know what spline would be the correct one though
Yes and no. What I did last year was not fix it on and just removed it once it was started. If it wasn't for the fact I need to warm the engine before a race, I wouldn't have one at all.
I blame tyre warmers myself.
maccas
Post by maccas »
Ben,
Thought this might be of interest to you!
Just noticed that both the front and rear wheel spindle on the 3xv are hollow as standard. Might be something else to think about.
Thanks Dan, that is interesting. Can you tell me the diameters please?
maccas
Post by maccas »
Also the swingarm spindle is too!
maccas
Post by maccas »
Yes no problem i'll measure them all now
maccas
Post by maccas »
Rear spindle:
Length to underside of bolt head: 330mm
Outer diameter: 20mm
Inner diameter: 14mm (apart from 45mm of 9.5mm I.D at the threaded end)
Weight: 450g
Front spindle (couldn't take it off as didn't have a stand, sorry mate)
Length to underside of bolt head (circlip in this case): 250mm
Outer diameter: 17mm
Inner diameter: 13mm (apart from 50mm of 9mm I.D at threaded end)
Haven't weighed it.
Swingarm spindle:
Total length: 300mm
O.D: 20mm
I.D: 13mm (apart from 30mm of 9mm I.D at threaded end)
Haven't weighed it.
These are from a R/RS model. The SP/SPR/ late RS models might use different spindles as the forks and swingarm are different, as are the chain adjuster blocks at the back.
Hope that's of some use :)
Thanks Dan, I'll get all those bolts drilled and lightened
maccas
Post by maccas »
How much do the stock spindles weigh Ben?
Remember I have a TZ front end, but will weigh them both on Sunday.
i like planting seeds me, got some titanium flat 1.5 x 30 x 500 good for brackets ect ,its yours
