Crank rebuild recommendations and Hi
salty
Post by salty »
I sent BDK a good crank for new bearings & seals - rods were fine, they replaced the centre but I provided the part (I bought one off them ages ago) they charged £187.32 - I was well pleased and will be sending them more.
Salty
I think I may phone them Monday.
I sent them 4 cranks, as the two they were rebuilding. they said need some webs. so they used the webs off the spare cranks I sent them.
both cranks had new centre shafts.
so £187 each crank+£70 new centre shaft= £260x2 =£520 +£50 as he said they charge £25 for each of spare cranks to split them down. :-k
I would say they have made a mistake.
Have you found any thing yet?
Gazjen
Post by Gazjen »
I've stripped it down checked the teeth on the clutch basket gear, crank seems fine etc etc the only thing I've found is I'm a clutch plate missing. I've rebuilt it but I'm waiting for my f3 valves and clutch parts to arrive and I'm also having a go at machining some S power valves for the centre ports.
The power valves were all set up wrongly too so I'm hoping she goes a bit better when rebuilt. :)
dave32
Post by dave32 »
So it was the clutch after all.
are you gonna fit new pistons?
what oil are you gonna use (gearbox and 2stroke)?
Dave
Gazjen
Post by Gazjen »
I'm still not convinced its the clutch as I said the tone didn't change, although I hope it is! gearbox oil will be ATF and 2 stroke oil will be a putoline variant. Pistons and rings are fine.
did you check if the big gear at the back of the clutch basket is still tightly fixed to it ?
Gazjen
Post by Gazjen »
Yes everything seemed fine.
Is the primary fixed directly to the back of the basket?
On Kawasaki triples they are riveted together with a hidden cush drive between the two parts that can cause some nasty noises when worn.
500bernie wrote:Is the primary fixed directly to the back of the basket?
Yep that's the same as on the AR125, the hidden Cush drive can wear allowing movement and a 'clattering' noise when ticking over. The noise goes away when the revs pick up / under load :D
dave32
Post by dave32 »
if its missing a plate it will make a a racket.
but if it is missing a plate, it can not possibly transfer the power ??? so basicly you shouldn't be able to run full throttle ?
Bit of a long shot but have you checked your balancer gear is aligned with the crankshaft gear?
And that the bearings on the balancer are all ok?
There's nothin' worse than a blabber-mouth cat
Howie wrote:Bit of a long shot but have you checked your balancer gear is aligned with the crankshaft gear?
I did that once, and this isn't the same.
the balance wrong by 1 teeth makes the bike unridable and actualy turns the hole bike into a vibrating plate :mrgreen:
Gazjen
Post by Gazjen »
Ok so I might not be a clutch plate missing, in the manual it states 7 friction plates or 8 depending on how you read it. I took it at 7, the photo in the manual shows 6. So I take it its 6 then?
