Posts: 3926 Joined: Fri Jun 18, 2010 11:29 am
Post
by Luders » Fri Mar 15, 2013 9:24 pm
ah it's too late for that now, but I did consider an offset. I decided to go straight through because I am a bit tight on space in that area.
THE FLUTE
Posts: 474 Joined: Fri Jul 28, 2006 1:18 pm
Post
by THE FLUTE » Mon Mar 18, 2013 7:13 am
This is how I did my 400 Ben
Posts: 3403 Joined: Mon Aug 02, 2010 10:22 am
Post
by 500bernie » Mon Mar 18, 2013 8:33 am
That is a nice looking solution
maccas
Posts: 877 Joined: Mon Sep 07, 2009 8:33 pm
Post
by maccas » Mon Mar 18, 2013 10:43 am
Very Yamaha-esque! I like it!
Post
by 500bernie » Mon Mar 18, 2013 11:09 am
Dymags and Brembos
Post
by Luders » Mon Mar 18, 2013 1:05 pm
Cheers Phil, Mike is working on something for me.
Will you and Gary be at Snet at Easter?
THE FLUTE
Post
by THE FLUTE » Mon Mar 18, 2013 9:00 pm
Luders wrote: Cheers Phil, Mike is working on something for me.
Will be at Snett mate and Gary is there but not riding with him this year. Doing F2 british and TT with Gordon Shand. Will you be there
Post
by Luders » Mon Mar 18, 2013 9:51 pm
yep I'm not riding though, so I'll catch you on the Friday for a beer
Post
by Luders » Sat Mar 23, 2013 5:45 pm
Fuel cell made, just needs fitting to the shroud
Next steps are to get the fabrication work completed on the frame and get the rear brake hanger made.
Post
by Luders » Fri Apr 05, 2013 9:54 am
I've been a bit quiet lately, but have been working on getting the fuel cell mounted and into the firbreglass shell and also trying to get the rear brake caliper mount sorted.
In the mean time my new master cylinder has arrived.
Post
by 500bernie » Fri Apr 05, 2013 10:35 am
That looks nice Ben
(nisin radial?)
Post
by Luders » Fri Apr 05, 2013 10:36 am
500bernie wrote: That looks nice Ben
(nisin radial?)
Yep
Posts: 1305 Joined: Fri Apr 18, 2008 9:41 pm
Post
by 375 » Fri Apr 05, 2013 3:27 pm
Fitted a radial to my lc/rgv and it had its first ride out on Monday was a massive improvement over the standard rgv one which has a lot of lever travel.
A tip i found when bleeding, i used a Hel bango bolt (in the master cylinder) which looks better than the standard one, i could not get much pressure after a bit of time, so i took it out and looked at the difference between the two and found the standard one has a bigger bore through the middle and is abit longer than the Hel one so swapped them over and was all done in no time.
Post
by Luders » Fri Apr 05, 2013 6:03 pm
Here's my rear caliper hanger in the process of being turned from a chunk of billet.
Posts: 927 Joined: Sat Mar 22, 2008 5:42 pm
Post
by fred » Fri Apr 05, 2013 7:58 pm
like it
