Anyone tried setting the float heights using this method and if so have any good tips or opinions on it?
I have been advised to set my float height to 18mm on my Rd500 as an engine tuner has advised the rd500 performs better with this set-up but I'm having problems achieving this using the above method!
Also anyone have a link to buying online geniune keihin carb parts? Allens don't have an online buying service do they?
I reckon the 18mm that he refers to is from the float bowl gasket surface to the extremeties of the floats themselves when the sprung part of the needle valve is just touching the bend-able float tang.
As an example the Mikuni TM 36mm carbs on my 3xv have a recommended float height of between 18.9 to 20.9mm. This by the fuel height method you have highlighted is 5-7mm.
maccas wrote:I reckon the 18mm that he refers to is from the float bowl gasket surface to the extremeties of the floats themselves when the sprung part of the needle valve is just touching the bend-able float tang.
Does that make sense?
Perfect sense thanks Dan =D>
I slept on it and it came to me in the night....lol.... plus the help of another rd500 forum member we believe it should be 2mm from the gasket face.
