We measured the standard carbs at just under 28mm with a fairly significant step inside the bore and managed to bore them out to 29.6mm which have to be bored offset.
We've calculated this to give just under 15% extra square area and with the smoothing of the bore this will probably translate to around 18-20% improved flow.
This isn't as substantial a gain as fitting 35 or 38mm carbs, but it does have the advantage that you don't need to make / adapt or replace the fuel tap, engine mount rubbers, airbox, airbox rubbers or throttle cables.
No doubt we will work towards providing those in the future, but we have a lot on at the moment (as always).
Anyway if this is of interest to anyone then they are quite welcome to get in touch with us.
A couple of pictures of the finished work shown below.
All the best,
Brock@BDK
01508 481713
