You can see around the valve hole where it's been rubbing, why can't they just make them the right size????
Need more space!!!!
All 4 valves equally tight, slacken all the head bolts a half turn and the valves started to free off. Another half turn, they all free off. The head gasket has clear rub marks from the valves. And several posts on here people have posted aftermarket head gaskets have caused tight valves, they've been fine when swapped for a genuine one. If it's the way it's assembled that causes the problem, that's handy news, but why? I know about assembling the head to the barrels first, making sure the valves and barrel chambers are clean (the parts all look like they've been blasted prior to re-building, but it was done by the previous owner) I've looked down into the barrels an it's all very clean, no carbon/sludge, clean as a whistle.Luders wrote:It has nothing to do with the head gasket, it's how it's assembled
They'd have to beKR-1R wrote:.
theres a guy on the bay selling some genuine used one cheap
