Motor temp.
Re: Motor temp.
Is the new thermostat a good'n ?
Have you put the stats in boiling water to test them ?
Re: Motor temp.
The thermostat is a new original one.
What do you mean by stats..? sorry..don't really see..
Mouser
Mouser
Re: Motor temp.
"Stats" Thermostats
Re: Motor temp.
Have you had the head off if so did you use a genuine head gaskit as pattern once dont seal to well unless you use a sealer?
Re: Motor temp.
Hi,
Don't know if the head gasket was changed. not by me yet.
Could this be the reason? wouldn't then the bike smoke clearly "white" and the water level be going down little by little?
Mouser
Mouser
Re: Motor temp.
maybee the changed the headgasket and used to many sealend and the cooling poorts are seald shut , than the water cannot run the normal route thrue the head and it wil be getting very hot.
Re: Motor temp.
That's actually a very plausible explanation Jarno. This over heating issue has had me a bit puzzled. I certainly don't think you'll get anywhere with it, unless you start taking things apart and inspecting stuff. I would still pull the head off and check it's straight.
Re: Motor temp.
Hi,
Will check that next week, hmm too much sealing compound could be an explanation..
I'll report..
Mouser
I'll report..
Mouser
Re: Motor temp.
Hello Mouserjarno wrote:maybee the changed the headgasket and used to many sealend and the cooling poorts are seald shut , than the water cannot run the normal route thrue the head and it wil be getting very hot.
what Jarno wanted to say.
so it should not be ..
cheers
Re: Motor temp.
JESUS!
Which jerk...what the f...
how stupid can one be to put 300 kg of gasket seal on the head!
hope it wasn't you..
Regards
Mouser
Regards
Mouser
Re: Motor temp.
So cleaned the radiator..changed nearly nothing.
Going to change the head gasket then..anyone know where to get only the head gasket, not the full set?
Which make do you recommend?
Mouser
Mouser
Re: Motor temp.
Only use OEM gaskets and do not use any sealant.
Re: Motor temp.
Ok, thanks!
Re: Motor temp.
Hi,
So I took off the head, there is very little sealant used but nothing in the holes, so nothing really seems to obstruct the water flow...
The sparks plugs are BR10EG.
Here are some pics of the head and piston.
The right head is quite scratched, the left one very clean.
What are thoses scratches?? Did those come the the piston??
What can be this overheating problem then?
By pusching the kickstart the pump drive does turn with, so it seems to work properly.
Mouser
Mouser
Re: Motor temp.
rest of the pics.
