balance shaft
Mouser
balance shaft
Post by Mouser »
Hi there,
So next problem with my KR1-s ....
The oil seal on the balance shaft (to the outer (left) side) seems to be leaking.
Is it possible to change it?
Didn't manage /see how to gett it off..
Mouser
Re: balance shaft
It would need to be split, much the same as on the crank
Mouser
Re: balance shaft
Post by Mouser »
Hmm thought so, but I don't really see how to split it...
Re: balance shaft
Specialist job, I wouldn't do one myself. SEP in Kegworth do all my crank based work.
Mouser
Re: balance shaft
Post by Mouser »
Aargh, shit!
Wouldn't know wo to ask here around..
No one ever did this on his own here, knows how dis balance shaft can get disassambled?
Mouser
Re: balance shaft
Hydraulic press and puller is the answer. Look for similar companies that specialise with crank rebuilds.
Re: balance shaft
and if you do it yourself, there is the difficulty of putting it back together in the correct position, not just simply press it on.
Mouser
Re: balance shaft
Post by Mouser »
Hmmmm, I see :roll:
