- tescr500
well smashing job, how's the fund raising going then Bernie.
Hi Wayne,
The fund raising is going like the rest of the project.....slowly
None of the painters have returned my calls or emails yet
- Top-shaggy
Yep... That sounds about right ... and when they say 4 weeks - read 4months500bernie wrote: None of the painters have returned my calls or emails yet
Not one I've found yet (who's any good) sticks to their promise
Always the little jobs that I under estimate
The front one is proving to be a bit more of a challenge.....just getting it apart
All that rust and crap just because someone couldn't be arsed to replace a split rubber boot on the piston
(thanks for the tip Martin, I should have it apart later today)
I wouldn't bother with that one and just get another one. It's exactly the same as most others from Kawa of that era and shouldn't cost much second hand. might even be cheaper that a seal-kit.
Hi Jan,
Even if I bought a second hand one, I would want to refurb it, as I have spent a lot of time and money doing the rest of the braking system.
I have got it apart, cleaned and painted now
Just need to wait until it dries and reassemble it
Rear brake done
(Front one tonight.)
- Binetta Steve
500bernie wrote:Hi Jan,
Ive just realised Bernie has a Chrome effect work bench! No doubt treated with liberal applications of Solvol.
It has had a hard life that bench
Well I eventually got the brakes fitted just need to bleed them next.
I always thought my rear mudguard had been cut down, but it would appear to be standard and uncut (when compaired with a NOS one
Come on Bernie get your finger out it will be winter soon.
You don't need to remind me375 wrote:Come on Bernie get your finger out it will be winter soon.
- Binetta Steve
Bernie 10,000 yes ten thousand views and its not turned a wheel in anger. Cum on lad get it out sans fairing just so you can ride it in the sun. Longest day Saturday, its downhill from then!
Thanks but once again the simple things seem to confound me
I am attempting to bleed my front brakes and the fluid is pissing out up the threads of the bleed nipple when I loosen it to pump the fluid through.
Pump, keep lever depressed, slacken nipple1/4 turn, lock nipple, release lever, pump etc, (I am using an easybleed, oneway valve and tube).
I am sure if the fluid is coming out of the threads, then air could be pulling back in.
It is taking an age, and I am getting fluid all over my caliper
Should there be something in the threads?
My bike may not have turned a wheel in anger, but I am a different matter
Front brakes done (just about) I may need a few more bleeds, but they feel good at the moment.
I was going to do the back brake, but I realised I dont know where the bracket is for mounting the res.
So, a job for tomorrow (later today).
