I have discovered a strange electrical fault with my KR-1S, when you push or operate any of the handle bar switches, horn button, or any other switch, the kips motor does a cycle of opening and closing, never seen this before.
Has anybody come across this before?
Any help on this would be greatly welcomed.
Thanks in advance,
Tony
Strange Electrical Fault!
- Steely
Re: Strange Electrical Fault!
I think it might be bad earth.
try again with a cable from "-" battery attached to the KIPS motor
- Steely
Hi Jan,
Tried the earth cable, no luck, just can't work it out.
Also could you help with this question, there is a 2 pole connector attached to the wiring that comes from the left hand switches, the wire colours are black & yellow & plain black, do you know what this connects to.
Thanks in advance,
Tony
Thanks in advance,
Tony
The connection is for the clutch lever switch (part of the side stand safety circuit).
- Steely
Thanks for the replies guys, but the problem still exists, any more ideas greatly welcomed, as I am stumped.
IS THIS WITH ENGINE RUNNING?...
... is it simply your battery is borderline flat and any item turned on triggers voltage to dip too low and kick cdi/KIPs ? give it a charge
try disconnecting the temp gauge (and clocks) I think this has a might live +ve feed that could supply a short circuit
start eliminating factors
is it left AND right bars?
with clocks and headlight removed?
