hi does anyone know about this
how do you test crank seals when motor is stripped down.
thanks safe cruising
how to test crank seals when motor is stripped down.
bsa70
- Light Smoker
Professor
Re: how to test crank seals when motor is stripped down.
Make sure there is some friction when you turn them
Maybe remove and use the flywheel side seal as a gauge for the others?
Hardcore you know the score
