There has been a lot of talk and requests vis-a-vis modification from KR1-S to KR1-R
Just to be clear the differences for the 'R' are the following:
Barrels very slightly different
Reed block insert different
Inlet manifolds different
35mm PWK carbs
Larger airbox rubbers
Larger fuel tap
Close ratio gearbox
Stickers
Paint
Well we're finally getting somewhere with the carb changes.
We have inlet manifold rubbers in production:
We have also been working on design of the airbox rubbers and are currently working on effectively printing sample rubbers with our 3D-printer.
Thirdly we have made matching inserts for the reed blocks to accommodate the larger carb diameter
Once complete we will be trying them out on a test bike we have here and playing with jetting and set-up of some carbs that we have selected for the task.
We will also run tests and jetting for the Airstriker PWK35's.
Please bear in mind that this testing is not an afternoon's work.
Besides changing slides, jets, lots of runs on the dyno and the like we will also need to remodel the airbox rubber and do the whole process again and again until we have what we see as a best result.
Finally might I remind you that there is an element of every bike being different.
Our test bike is fully standard.
We have a gentleman close to us with a set of JL pipes, increased airbox opening and F3 KIPS valves who intends us to make him a set with airstrikers which should give us an indication of set-up for those with JL's.
This is just a taster to let you know that we are committed to the project and well on the way with development - the point of no return has passed.
If you're interested in the projects or updates about it please feel free to drop me an email and I'll keep you up to speed when we get some worthwhile results.
All the best,
Brock
brock@bdkraceeng.co.uk
