Oil pump pipe ends broken off!!!
waza1972
Post by waza1972 »
Does anyone know of anyone/anywhere that has the two pipes that come from the oil pump and go into the inlet rubbers? Cradeley kwak dont have them. I finally got mine running the weekend and once I had turned it off i noticed two stroke oil leaking from behind the plastic cover that covers the pump. When i removed the cover I found that the two pipes have sheared off on the eyelets where the banjos pass through.
Kwak part number is 92059-1963
Cheers Waza.
ashleykr1
Re: Oil pump pipe ends broken off!!!
Post by ashleykr1 »
I Also need the size and a source to replace them as I've snapped one, in the same place.
Some on ebay, make an offer....http://m.ebay.co.uk/itm/Kawasaki-KR-1-K ... nav=SEARCH
waza1972
Post by waza1972 »
I ordered these, but they called me back to say that the
pipes are cracked.
Rocket
Post by Rocket »
I think I may have some of these pipes, will try and have a look today at the workshop if I get time.
Rocket
Post by Rocket »
Got a set, came off a running bike but 1 pipe has a joint in it, seems to be oil/air tight joint though,
see following photos,
contact me if you are interested in them,
Mark.
waza1972
Post by waza1972 »
Hi Mark, I think I have sorted it now witha couple of hydraulic banjos and fittings and connected them with vacume pipe. I still have a problem with the revs hanging at about 2k. How much do you
want for them and where are you?
You wouldnt also have a spare throttle cable would you or know wher i could get one made up?
James P
Post by James P »
waza1972 wrote:...You wouldnt also have a spare throttle cable would you or know wher i could get one made up?
Venhill will make you one, or sell you the bits so you can make it yourself. You may also find other firms which offer similar parts and/or service.
