I've snapped a Power Valve!!
jonny1deck
- Newbie
I've just put new pistons, rings, put the barrels on, all good! But then I put the head on which was a bit tight going over the power valves, then snap!!! So has anybody got a spare one and what was I doing wrong??
- the-elf
The trick is to assemble the cylinders, power valves and the head on the bench and torque the head down. Make sure that the power valves can turn etc. Then once thats done put the complete top end onto the engine and torque down the bottom of the cylinders. The reason is that the cylinders may not be perfectly flat or the same height and if you put the cylinders onto the crankcases first you can twist the head when you put it on.
Don't forget to re toerque the cylinders to the crank case again after the first heat cycle.
jonny1deck
- Newbie
- mr_bungholeo
mgtkr1
this seems to be one of few faults with the kr. would it be wise to have cylinders machined flat as PB did this via v.p engineering to good effect! the bike was raced by steve marlow and prepped/fettled by the late J.R with which they gained a few nags just by improving tolerances. 57h.p was produced at some point with minimal tuning (ledar intake stacks etc). i believe this same bike only made 44hp initially although kips were assembled wrong. the reason i ask is because my bike is fitted with 26j pistons and need to know if machining would effect anything regarding squish/clearance. will also have head matched to suit new piston profile. cheers matt
- mr_bungholeo
jonny1deck
- Newbie
All running but not that well.
I've put it all back together, started first kick sounded not bad, done the heat cycle. Just taken it out round the block it won't pull away without dipping the clutch then seam to have the power of a 125!! Also the gearbox is very stiff, I've changed the oil but still the same!!
Also the power valves on one side vibrate alot more than the other side???
- the-elf
Are both cylinders firing? check the HT leads etc. Are you sure you got the powervalves set up correct?
- mr_bungholeo
sounds like u got them back to front!!!...n the clutch drag is the washer in the basket...behind the center...or the actuating arm.....any wear on the washer will screw up the clutch..changed mine on elf's findings even though wear was minimal..it turned a crap clutch into a perfect one....glad u never snapped another though...only got one left....
danny harris.....R.I.P
gone but totally forgotten...
jonny1deck
- Newbie
